One UI 7 Battery problem
(Topic created on: 06-08-2025 12:41 AM)
RickDas
Tech Talk
OneUI 7 Users if you also get massive battery drain problem then factory reset your phone, it will help you a lot. Here's my before and after factory data reset result
cs_member8
Tech Talk
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
