No change after switch on power saving mode ......
(Topic created on: 05-21-2025 12:06 PM)
Tech Talk
As you see on the post that while switching on or off of power saving mode, there is no change in battery life duration.
Why is it a software issue or something else? I didn't figure it out ... .. help me with your valuable feedback and response
7 Comments
BiRdMaN
Tech Talk
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Tech Talk
It means there is no use of power saving mode
Rochitd14
Tech Talk
Change will only show if you enable other options like limit cpu to 70%.
These option are by default enabled to give maximum battery life, but in your case you have disabled them. Only turning off aod will not do any change. At least enable limit cpu usage or decrease brightness.
Tech Talk
That I know, but this is not a massive change
vrushabh__6
Tech Talk
My buletooth will be unpaired to paired in Samsung galaxy f15
Tech Talk
Reset your settings it may work.
Go to settings, then General management, scrol down u wl C reset option, then click on that u wl get options, then click rest settings, click reset wifi & Bluetooth settings
SatsangiDevan
Tech Talk
It's not samsung galaxy now it's bugs galaxy
