M31 charging problem
(Topic created on: 04-24-2020 03:43 PM)
karti0211
Tech Talk
Charging issue greeting worse...one and half hours for just 16%...how many of you facing this problem
12 Comments
raju-83
Tech Talk
I am also facing Battery Charging issue. It takes 3 Hrs.+ to complete charge from 10 to 100%.
You may pls report directly to Samsung through "Send Feedback".
karti0211
Tech Talk
for me it won't go after 62%
karti0211
Tech Talk
I did..you too send feedback to samsung so that they come to know our problem
MPŔ
Tech Talk
my m31 take 8hours to full from 30to100
prachinnu
Tech Talk
Dear Samsung Customer Support Team,
though the fast charging option is enabled, it is taking more than 3 hours to get fully charged. With your solution
cs_member9
Tech Talk
Dear Samsung Member,
Kindly follow the below mentioned step to enable the fast charging mode of the device:
Settings> Device care> Battery> Three Dots> Settings> Fast Cable Charging
Note: We recommend to use Samsung fast Charger in order to charge fast charging
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application> send feedback > error report/ask questions).
karti0211
Tech Talk
it's in fast charging mode only...
prachinnu
Tech Talk
though the fast charging option is enabled, it is taking more than 3 hours to get fully charged. With your solution, the problem is still not solved. please suggest better solution soon. Its not even one month me buying this model
Prabha
varadp
Beginner Level 3
Tech Talk
I am facing the same issue. Although, in the first month the battery used to get fully charged around 2 hours. Now it is so slow that it is taking more than 3 hours o
to charge. I took the help of Samsung via Customer support chat service, but all they suggest is to enable fast charging or factory reset or change the adapter, etc which I have already done. But the same problem persists. This is very frustrating.
