Help me (networks problem)
(Topic created on: 08-09-2021 01:31 PM)
Kawsar4s
Tech Talk
My mobile has a network spot, what could be the problem, how to fix it, data connection is slow.
See screenshot
10 Comments
Tech Talk
Its probably the network providers issues
Because its showing very less network bars in your device
Kawsar4s
Tech Talk
How to solve this problem?
Tech Talk
As previously said its your network provider issue ( probably)
Check the same network provider with different device if its still giving low network you can't do anything
Tech Talk
REINSERT SIM ONCE
THEN CHECK !
IF NOT WORK
THEN DO
RESET NETWORK SETTINGS
TRY THIS !
NoelCoelho
Tech Talk
Go to settings, Access Point Names. Change the Bearer to 4G. You may get faster data speed😀
Kawsar4s
Tech Talk
Give screenshot!
Kawsar4s
Tech Talk
No 4G i have LTE
Tech Talk
YES I ALSO HAVE LTE NO EXISTING OF 4G IN APN SETTINGS
SUGGEST YOU TO
Access Point Names > Click on 3dots >Reset to Default
don't change anything !
Kawsar4s
Tech Talk
No 4G available but other sim operator give 4G connection, or 4G available, i complaint to customer care.
