Help me ,I am facing many heating issues in my s9plus, even after charging it
(Topic created on: 04-09-2020 04:38 PM)
leanotech
Tech Talk
#heat
#heating_issues
#flawsdetected
#s9pluss
#s9
#need_help
5 Comments
Amanpundeer
Tech Talk
As the phone usually heats while charging try to close background applications and avoid usage of phone while charging.This might help from heating.
leanotech
Tech Talk
yes that's true but this particular conditions is not usual
singhgovind
Tech Talk
  1. Turn off your Galaxy S9 immediately.
  2. If charging, disconnect it from the charger.
  3. Allow it to cool off and then turn it on.
  4. Continue using it to know if it still heats up that bad.
  5. Reboot it in safe mode and continue using it.
  6. Factory reset the phone and see if it still heats up
leanotech
Tech Talk
I believe it is due to some issues in battery
Mohanish007
Tech Talk
because Samsung giving us Exynos processor...
