Galaxy S22 might come with a next-level cooling solution
(Topic created on: 07-09-2021 11:01 PM)
AshuAgrahari
Tech Talk
Smartphones are getting thinner and more powerful than ever before. Running the internals at max performance generates heat. These devices thus need robust cooling solutions. Otherwise, the only option left is to throttle the device to bring the temperatures down, reducing performance in the process.
That’s why most gaming smartphones rely on vapor chamber cooling. Samsung has utilized this technology on some of its previous flagships but later gave up on it. Rumor has it that the company might be thinking about bringing it back.
Samsung might bring back vapor chamber cooling
Vapor chamber cooling has long been used in high-performance computers and smartphones. A flat vacuum-sealed metal canister with a very small amount of liquid is used in smartphones. Once it heats up, this liquid turns into gas and then condenses when it cools. It goes back to the heat source through a secondary channel. This, coupled with the larger surface area of the chamber, allows for faster heat dissipation compared to a conventional heat sink.
Samsung has used vapor chamber cooling on devices like galaxy S10+. The Galaxy S20 and Galaxy Note 20 series phones had it also but not on all units. Teardowns showed that some units had vapor chamber cooling while others had a multi-layered graphic thermal pad instead.
A report out of Taiwan claims that the company’s supply chain partners and suppliers are preparing for Samsung’s vapor chamber development. They believe that Samsung will bring this cooling solution back with its 2022 flagships, possibly starting with the Galaxy S22 series.
A vapor chamber would bring significant benefits. Lower temperatures would allow the chipset to be run at peak performance for longer, providing users with an enhanced gaming and multi-tasking experience. Whether or not this rumor turns out to be true is another matter altogether.
ShyamMohan01
Tech Talk
Why put in so much effort? I can use my S20 fe as room heater in winter. Thank you Samsung for this truly multipurpose device
