Resolved! Solved
Fonts for OneUi 2.1, 3.1, 4.0 and 4.1
(Topic created on: 04-11-2022 09:22 AM)
AjayBhojaniAB
Tech Talk
3rd party font installation in your Samsung Galaxy devices.
Hey folks , Want to install fonts in your Samsung Galaxy ?
( OneUi 2.1, 3.1, 4.0 and 4.1 )
Seem like It's very easier then ever, just download 1 file and boom it's done. So let me explain actually process. Might be some you geeks already know about this process.
  • Download the zip file from link and extract the zip file.
 > Link 1 - MediaFire
 > Link 2 : Google Drive
  • Move the extracted folder in to internal storage (like it should be > "internal storage/monofonts" don't change name or anything from the folder).
Location of the folder where fonts must be stored in .apk format
  • Open the folder and install apk called #mono_ 1.0.apk ( Give storage access )
  • Open the installed app from app drawer and you will see the screen as it's shown in the screenshot.
Here you can see the lis of fonts in #mono_ 1.0.apk
  • Now tap on any font ( probably all will be in com.monotype.android.font..apk format) , So tap on any font you want to install from the list.
  • Wait for the installation process and boom it's will be available in Settings>Display>Font size and style.
  • Select any font you want to use in your device and ahh it's done.
Notes :
  • I'm not a creator of this app/s.
  • Device i tested with : Samsung Galaxy F41 ( A11 , OneUi 3.1 ) and Samsung Galaxy M21 ( A11 , OneUi 3.1 ) and it's seems fine working for both device.
  •  Don't uninstall #mono_ 1.0.apk until you don't want to use custom fonts, if you uninstall it then installed fonts won't work anymore.
  • Found this method from YouTube : YouTube Video link
Still here putting this for the proof😂
Tech Talk
Thanks for Info 😌🙂
13 Comments
vivek1989
Tech Talk
Bhai oneui 4.1 ka design my files pasand nhn aaya oneui 3.1 ka my files colorful tha
AjayBhojaniAB
Tech Talk
I don't use Samsung File Manager 🤣🤣
Tech Talk
Thanks for Info 😌🙂
AjayBhojaniAB
Tech Talk
Thank you for testing 😊☺️
Strangeneria
Tech Talk
Well done 👏 😁
AjayBhojaniAB
Tech Talk
Thank you 😊
SohanNayek
Tech Talk
This is not official. So don't do that
AjayBhojaniAB
Tech Talk
That's what I wrote " 3rd party ".
Not applicable
Tech Talk
Bro Zfont 3 work nahin kar raha hai Android 12 One 4.1 mai
