Battery issue
(Topic created on: 07-02-2020 12:20 AM)
Samsung_C9d2G2W
Tech Talk
I am using M31 for past 3 months. At first it was just awesome but now the battery is draining fast. Also it is not supporting fast charging, it takes more than 2 hours for full charging. Any suggestions for this issue.
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We are very sorry for the inconvenience caused to you, please be assured and to resolve "charging" issue kindly follow the given below steps:
1. Safe mode:-Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
Note :-To exit safe mode restart the device .
2. Check charger functionality:-Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
3. Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report) along with Screen-shots(time taken to charge). This will help us to further investigate and resolve your concern."
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
