Battery drain
(Topic created on: 12-29-2019 06:40 PM)
karthik47
Tech Talk
After updating the November patch update the mobile is drain quickly. I don't know why this is happening. If anyone knows about do tell me.
2 Comments
nikssharma
Tech Talk
i am facing the same issue after the november update,once the battery level reached at 50% it start draining quickly and at 5 % with in 20 mins
mkarthick
Tech Talk
reset ur phone and check the battery if it same issue is happened go to nearby service centre
