Battery drain
(Topic created on: 04-03-2022 12:23 PM)
yathi_raj
Tech Talk
Hey can someone here give me a solution for faster battery drain for samsung galaxy s21+ indian varient handset please .
5 Comments
UchihaR
Tech Talk
put your unnecessary apps in sleep mood or deep sleep mood. in battery section you just set a time for daily optimization mood on everyday, night time will be better, when u don't use your phone. atleast 3days auto restart at night time differ from the optimization time. if still don't solve the problem, then it's your mobile network and mobile data unstable problem by the operator. try to make cool the phone most of the time. hope it will be helpful.
yathi_raj
Tech Talk
Thanks alot for the information . But i hardly use applications in this mobile and yeah as you said there might be chances of unstable network from provider . Will look into this .
UchihaR
Tech Talk
welcome bro.
TheMystic
Tech Talk
cs_member8
Tech Talk
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
