Battery drain very quickly in s20 fe
(Topic created on: 11-07-2020 11:47 AM)
sumitborkar
Tech Talk
Hello
I having an issue with my phone battery drain very quickly i have already set the standard setting but phone gives only 4 to 5 hours backup and heating also quickly please anyone help me i have updated app and os also
39 Comments
FearLesS007
Tech Talk
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
FearLesS007
Tech Talk
if my given settings/comments are useful and informative for you then you can accept as solution by CLICKING on 3DOT at my comments
Ehsank
Tech Talk
what is this bro? just copy paste😄😄🤣🤣
Ehsank
Tech Talk
even this comment copy paste, what are you doing ?
Ehsank
Tech Talk
this is not expecting from you, you are at level 6 on this forum and doing like this, did you see here anybody doing like that? every one share their own suggestion or share other post
Ehsank
Tech Talk
in my opinion, its not good at all, to copy and paste other comments, if you think any post or comment is good and valuable then you can refer /share the link of that post ir comments on that post
think again if you are planning to do it in future
it morally wrong
Ehsank
Tech Talk
mujhe nahi lagta k tumne kbhi aisa kya hoga ,jo khud karta hai or jaanta hai wo copy paste nahi karta ir jaise tum bol rahe ho k formate change kar dunga usse yehi pata chalta hai , copy paste me hi tumhara time guzarta hai, its ok agar tumhare lyie ye normal hai main samjh sakta hu aise tum pehle nahi ho jisne aisa kya hai
Ehsank
Tech Talk
aisa ho nahi sakta k tum ne khud aisa kya ho, impossible warna tum apne ideas apne way me share karte
so ab copy paste k baad jhut ka pitara mat kholo
FearLesS007
Tech Talk
lol f9 bri jaisa smjna smjlo but this is truth jo mene btaya, itna same likne mei kyu time waste krta mai ? 😅
