Auto reboot problem relief
(Topic created on: 08-25-2022 07:08 AM)
Ankan47
Tech Talk
🔥 Guys , who are facing auto boot up problem , please clean your ram before it reaches 3.7 GB for 6 gb phone. & 4.6 gb for 8 gb phone,,,,
It helps,, don't need to believe me ,,, JUST TRY IT,
& have a great day everyone 💙
8 Comments
ㅤ
Tech Talk
mHappiee
Tech Talk
ㅤ
Tech Talk
Actually no one knows the actual reason behind this motherboard failure..
And some saved in the middle..and most reached at the last stage(dead)
U r lucky.. if ur device saved. 🙂
"And No Any Trick, Played By Our Side, Can Solve This Problem"..🤷
mHappiee
Tech Talk
Okay... So "Jabtak hai Jaan, Jabtak hai Jaan" chalate raho... And device can fail anytime 🥲
ㅤ
Tech Talk
Just keep a backup of ur device...
Bcz.. tumhare phone ne kuch kuch hint to de hi diye hain...😬..
mHappiee
Tech Talk
Hmmmmmmm....
mHappiee
Tech Talk
I don't believe you ... won't try ... 😬
I think I have already solved this issue on my device... and it's not some RAM issue I believe
mHappiee
Tech Talk
Maybe it's possible that this method works on your device... but what is the use of buying device with big RAM if you cannot use it fully ?
