Android 11 - Battery draining & Heat Issue
(Topic created on: 01-02-2021 10:08 PM)
MN5797
Tech Talk
After updating my S10 Lite to Android 11, my battery is getting drained so quickly and the device is getting heated like never before. Is there any solution to this or should I wait until Samsung fix this issue?
12 Comments
Ehsank
Tech Talk
after update, so wait for few days and as of now do these steps
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable/type C earphone only for Android 11)
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
You can also send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
Ehsank
Tech Talk
and also i suggest you if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
KunalKalra
Tech Talk
Just switch Off phone for a few minutes and switch it ON again.
Then go to Settings > Device Care > Optimize Now
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file again along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
pkokoshnikov
Beginner Level 3
Tech Talk
The same issue with my s10e. After upgrade to Android 11 battery is getting drained very quickly. It's not enough even for day using.
BhAnu619
Tech Talk
my s10 plus having heating problem and battery draining after android 11 update... what should i do for fix this problem.
BhAnu619
Tech Talk
please help me samsung team
otherwise i will never buy samsung mobile..
i am s series user from samsung s1 mobile
but this time you disappoint me
pankajtheboss
Tech Talk
I'm also facing same problem with my s10 after update to android 11,phone start heating,camera got blurred and battery draining,anyone tell me when Samsung will fix this issue
mech7
Tech Talk
I have the same problem the heating issue went away with a restart but its still draining battery on s10. With the android 11 update.
