⚠️ Solution: No battery icon after updating to One UI 7 ⁉️
(Topic created on: 05-13-2025 01:36 PM)
SataruGojoo
Expert Level 3
Tech Talk
After updating to One UI 7Some users are facing an issue in their phone.
Like,
- INVISIBLE BATTERY ICON, Or Disappearance of Battery Icon🔋, Alarm etc.
Solution:
1. Turn off all the Goodlock modules before Updating to ONE UI 7.
2. (See the attached screenshot)
 - Follow the above 2 steps to Take precautions.
- A Post from Developers regarding this issue:
Another solution, Screenshot.
Read more tips about Software Update-
Post #1https://r2.community.samsung.com/t5/Tech-Talk/️-Read-this-post-before-updating-your-phone-to-ONE-UI-7/td-p/18796868?src=ShareByUserCM
For more updates, keep in touch.
#SataruGojoo
8 Comments
Tech Talk
Mention in the title that this post has the fix for the same issue
SataruGojoo
Expert Level 3
Tech Talk
Now Check
Tech Talk
Nice
SataruGojoo
Expert Level 3
Tech Talk
Not applicable
Tech Talk
https://r2.community.samsung.com/t5/Galaxy-S/️ATTENTION-️ONE-UI-7-️MAJOR-BUG-️/td-p/19401855?src=ShareByUserCM
SataruGojoo
Expert Level 3
Tech Talk
Probable solution:
Step1- Clear App data of Google Play Store.
Step2- Uninstall update of Google Play Store.
Step3- Restart the phone.
Step4- Keep Mobile data ON, Try to open the Google Play Store app once then exit the app, as the Google Play Store will update automatically.
Step5- 'WAIT'
Step6- after the update (Of Google Play Store) this issue should be solved.
Not applicable
Tech Talk
thanks for your suggestions! will try what you've said and see if it works or not.. thanks!!🙏
SataruGojoo
Expert Level 3
Tech Talk
Did it fex?
