What's ambient display features it's completely draining batt scrn usage is 0min
(Topic created on: 12-11-2024 05:31 PM)
CJSwarup
Tablets
It's completely draining battery to zero percent. There is no option to turn it off. What to do?.
8 Comments
Brij92
Tablets
In settings menu go to display > Screen saver > put it to none
CJSwarup
Tablets
It's already in that 'none' option..
Brij92
Tablets
you have always on display in on mode?
CJSwarup
Tablets
No there is no option like that showing even...
Brij92
Tablets
Go to display down there u will find always on display if on switch off that
vivek1989
Tablets
Do u use photo ambiant for screen lock?
CJSwarup
Tablets
No..
cs_member8
Tablets
Dear Samsung Member,
we understand that this happened after software update and please believe that this is not the kind of experience we want our customers to have.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Perform Battery Optimization: Battery optimization helps you to boost the battery performance of your device. To check battery optimization: Settings > Select Device Maintenance/Device Care/Battery and Device care > Optimize > Optimize all options like Battery, Storage, and Memory
● Turn off Wi-Fi, GPS, Bluetooth, etc.
● Kindly check whether the mobile network fluctuates frequently or the network signal is low in your area. In both cases, the battery will drain considerably fast. We recommend you avoid usage in areas with low network/fluctuation.
● Reduce display brightness level: Kindly set the device display brightness in auto mode;
* Steps for setting display brightness in auto mode: Swipe down on the home screen to open the notification panel
* Turn on the Auto brightness option if available.
* It will automatically adjust the display brightness of your device according to ambient light & will reduce the battery drainage.
● Adjust screen timeout settings: Settings> Display> Screen timeout> Select minimum screen timeout.
● Kindly check which application is or interface is using more battery from device care. And try to update app or avoid using that app.
● Kindly check which application or interface is using more battery from device care. And try to update app or avoid using that app.
● Turn off auto sync of e-mails, app data, etc. we request you to turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
● Steps to turn off auto sync are: 1. Swipe down on the home screen to open the notification panel.
2. Turn off the auto sync option.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
