Resolved! Solved
TabA7 charging problem
(Topic created on: 05-22-2021 09:51 AM)
Jeeban95
Tablets
Brought tabA7 last month. Tab is showing charging issues. Continues to charge even after 100% . After the battery shows 100% it takes almost 30-40min to show BATTERY FULLY CHARGED. Can't visit service centers because of lockdown. Is this charging normal? If Anyone else facing this issue plz do reply.
Tablets
No, I also face this issue on my tab A7 it has android 10. I don't think this is a problem this is normal dnt worry
If u find this helpful kindly click on the three dots and click accept as solution
12 Comments
Tablets
I also have the galaxy tab A7
Tablets
Did u recieve android 11
Jeeban95
Tablets
Yes
Tablets
I still didn't recieve
Tablets
If yes, did the problem start after the update
Jeeban95
Tablets
No... the problem is in Android 10 it was not showing expected time to complete charge.. bt in A11 it shows the time. After 100% THE ESTIMATED CHARGING TIME INDICATOR GOES AWAY N YHE TAB CONTINUES TO CHARGE.This was happening in a10 too but I thought that it's normal. Provided the charging time indicator is available now I think it's a problem
Tablets
Do u live in India and in which state? I live in maharashtra India.
Still did not recieve android 11
Jeeban95
Tablets
Yes am from Odisha. You'll get the update within a wk or two. Coz update in wifi model gets followed by lte version . I received the update 2wks back .
Tablets
No, a person from karnataka also recieved update, he has wifi mdoel, I don't know why still I didn't get update
