Problem facing in S7 fe auto brightness sens
(Topic created on: 09-20-2022 04:44 AM)
Not applicable
Tablets
Hello,
While I use my tab horizontal tht time it's brightness gone to zero evn I not cover camera area, it doesn't mean how you using it's only single sensor is working I tested this with many play store apps but whenever I cover one by one both sensors the near camera sensor is not responding anything.
Recently I given my tab in authorized service center to resolve battery issue and second problem was software error and after tht I facing these problems.....
Initially I was a big fan of Samsung but after getting this problem my thoughts are going to change.
kindly resolve this as soon as possible because tab warranty period also near to complete...
3 Comments
abhinavkrpcse
Tablets
It's costly product btw.
Jameswalter
Tablets
To troubleshoot the problem, reset Adaptive Brightness settings in the Device Health Service app. If not, perform a routine sensor test to detect hardware issues. If the sensors are working, try using third-party Android screen brightness apps as a workaround until a permanent fix is released.
Not applicable
Tablets
Dear i already Done all these things but tht was showing problems and thn o contact samsung support they identify problem in motherboard and that was replaced now it's working fine 🙂
And thank you too
