incoming call erorr busy my number all time solution...
(Topic created on: 06-23-2018 08:29 AM)
akkipathan12
Samsung Wallet
only out going call on but incoming call is blocked please solution
2 Comments
rsamandeep
Samsung Wallet
Oreo Update for J7 pro http://zipansion.com/1jASq
admin_
Samsung Wallet
We do apologize for the inconvenience caused as you are unable to get the incoming calls. We suggest you to check below steps to fix the issue:
- Navigate to phone app>>3 dot>>settings>>Block numbers>>Block unknown callers>>disable.
- Navigate to phone app>>3 dot>>settings>>More settings>>Call barring>>Voice calls>>Incoming calls>>Disable.
- Contact the network service provider if still issue persists.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
