Galaxy J7 Max 92%Problem πŸ˜‚
(Topic created on: 02-01-2018 10:59 AM)
Nithiz
Samsung Health
My Galaxy j7 max is not charging after 92%It takes more time after 80-90 but it not exceeding 92... Bring me Solution As soon. Already I had galaxy J7 I faced similar problem With that phone too... Bring an update to fix this problem
9 Comments
JenniferSamS
Samsung Health
Hello,
Dear Mr. Nithiz
you need format your device and reboot it again as i have all the same problem but now its solved with this solution better to create backup from device and then put it in format or reset mode...!!!!
Aif
Samsung Health
today again after 20 days, i noticed that my phone charged upto 88% then after that it went  to 80% then it took half an hour to charge from 80% again to charge 88% then after it goes directly to 94% , but the battery after i used phone was normal.... so i want to know is it normal, on samsung nembers i checked the status of battery , there it showed battery status normal,
so i want to know that my phone is normal....
j7nxt,
is any j7nxt user is facing the same issue, i want to know is it becoz of fota update or something else..
Nithiz
Samsung Health
thank you so much bro i will try it soon...
MaverickSumit
Samsung Health
Don't need to format your device.
Follow this Step-
1-Turn On Ultra Power Saving Feature on your phone
2-Let it get switched off automatically by not charging it
3-Keep your phone on charging with the adapter provided by samsung for 150 Minutes
Switch on your phone and your problem will be solved
This is the way a samsing executive had told me when i had the same problem with my S6
Samsung Health
I show in service centre they changed charging Jack
lakshit12
Samsung Health
is your problem solved after changing charging jack
Amitgkp
Samsung Health
same problem with on max
you can charge your phone morning time without any usage
admin_
Samsung Health
"Thank you for Joining Samsung community. We would recommend to follow some troubleshooting steps to further isolate what you may be experiencing. Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1116006. Please let the us know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. Be sure to hit β™‘ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Not applicable
Samsung Health
samung team is asking to visit service centre guys i have spoken to them very badly now itself
