battery draining fast solution
(Topic created on: 01-25-2020 04:30 PM)
devang77
Promotions
Dear all Samsung Members and Customers,  i am always listen to my battery draining very fast i will tell you that if you forced stop the Samsung Paymini App then battery will not draing fast. Go for the battery saver mode and sleep this app because it's open automatically, you will also need to sleep this app.
13 Comments
Arif1050
Promotions
hey bro there is no option to disable the Samsung pay mini in galaxy a50
than how to disable it ???????
devang77
Promotions
force stop
devang77
Promotions
force stop and go for the battery saver add this app for sleep mode automatically
Amansinha9
Promotions
I don't think so, because in my A50 it shows that this has used 0% of your battery from last fully charged !!
devang77
Promotions
force stop
Amansinha9
Promotions
But there is no need !!
devang77
Promotions
check your truecaller, shareit ,
Amansinha9
Promotions
well I am using none of it !!
devang77
Promotions
i am using a30 my battery backup is 2.5 days nows
