j7 2016 volte problem solved
(Topic created on: 07-15-2018 07:06 PM)
msd7781
Others
after latest update in j7 2016 device volte,ultra data saving mode and s-bike mode stopped working.
here is the 100% solution .
https://youtu.be/CsxXUAXuObo
please subscribe the channel if it helps to you.a737aae5-f503-414d-9198-cee9d25b57b6.jpg
50 Comments
PrinceAmerali
Others
Just Go to recovery mode
power off handset n just hol volume up+home+power button for 10 seconds and clear cache partition and reboot system repeat this step 4_5 times continously volte will be activate successfully it works 100%
meenaBS
Others
Yes it working
PrinceAmerali
Others
meenaBs Aagaya volte apko
GRpatelmathni
Others
reset bhi kar diya fir bhi nahi hua
msd7781
Others
try this -it works 100%
GRpatelmathni
Others
factry reset par bhi nahi ho raha hai akhir problum kya hai 4g par calling kyu nahi ho pa rahi
msd7781
Others
kailash1992
Others
saale log ko problem samajh me nahi aa raha to reset karne se problem thik hoga , operating software me problem hai .
msd7781
Others
try above method it will work 100%
Monusah
Others
I am having this kind of problem how it will be solve
