Scheduled power off & on function is not working.
(Topic created on: 01-18-2022 07:40 PM)
santosh3471
Others
I am using Galaxy J7 Pro for more than last 4 years. It is now became a bit slow but still working nicely.  Since last Security update, Scheduled power off & on function is not working even though it set properly. Can't understand why this happened. Please help.
cs-member13
Expert Level 4
Others
Dear Samsung member,
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
Please follow the below steps:
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Error report).
Warm regard,
