Sherwinjo
10-26-2021 10:48 PM in
Others
I'm currently using Samsung S10 lite. It has an amoled display, tho the color quality and the picturization of blacks are not quite good. There is a breakage in pixels. Is it a manufacturing defect or is it totally normal?
If so what can I do about it?
12 Comments
- « Previous
- 1
- 2
- Next »
Sherwinjo
10-27-2021 02:00 PM in
Others
Okay
Samsung_Support 2
Expert Level 3
10-31-2021 12:00 PM in
OthersDear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Whether it's a product repair or just some help and advice. There are authorised service centers across the IN that can help you.
rathumar
11-07-2021 10:36 PM in
Others
Sherwinjo is your problem solved? I have the same issue
- « Previous
- 1
- 2
- Next »
