🔥Reduce heat by 10% on S22UltraGen1 and every device running 4.1,4.1,3.1fullUI
(Topic created on: 04-09-2022 06:32 AM)
AlenSony소니알렌
Others
<html>
We all know here at India its summer and is so hot 🔥 humid so its normal to gadgets to heat🥵 even wearables are heated when charging. (example my buds pro,)
So here is a Small Tip to reduce heat 🔥 by 10%
*After All install follow the images I given below
( if you can't see this post images click the link on the comment section and open with browser by copy paste)
*do everything shown on the
images
Here:
Step 1
OPEN THERMAL GUARDIAN AND REDUCE THRESHOLD BY -2°
STEP 2
GO TO ADDITIONAL SETTING
THEN SELECT ALL OPTIONS
Click apply and done !
<b> All Set ! </b>
</html>
-ChoeHa-U
14 Comments
Others
If so then try downloading this from Galaxy store
I bet you can't find this in your galaxy store 😏
(Only for 삼성 Korea)Screenshot_20220409-141646_Gallery.pngScreenshot_20220409-141543_Gallery.png
Vikas031
Others
Step 1 done,
Step 2 is not available means the app does not show the option of additional settings.
Others
You need One UI 4.1 device
cs_member8
Others
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
_Sayujya_
Expert Level 3
Others
😆 i just use my kernel auditor to bring my device in 500mhz and it cools down faster from 42C to 32c
