Power button not behaving as power button
(Topic created on: 06-25-2025 10:48 AM)
SMSourov
Others
Who on Samsung thought to change the behavior of power button from the power button to assistant button though the user has modified the behavior to power button before update?
After updating to One UI 7, I was faced with this. I don't want the power button to behave anything other than a power button. If I had wanted it to behave like anything other than power button, I would have wanted a separate button. I wouldn't have spend some time of my life to find the option in the Settings app to change this behavior.
2 Comments
sidharth3768
Others
You can change its behaviour and turn it back to behave like a power button from the side button settings.
SMSourov
Others
I can do that. But that's not my main point. My point is that if the user has modified the behavior of a feature to its liking, it should not be altered.
