Poor quality problem
(Topic created on: 03-13-2023 09:29 AM)
ASH_37
Others
Hlo guys, samsung a53 has wrost quality while uploading photos and even when I'm recording tiktok its quality is being downgrade has anyone have facing same problem ??
6 Comments
vivek1989
Others
Yah bro its camera isundtable
Whenever i open the camera it stutters for a while and when i try to close it ,it does not closes rather it hangs
I m facing this ptoblm now frequently
Are u this problem bro
Others
Sorry for the trouble. You can set the camera accordingly your need and also you can try resetting your device.
If you find my advice helpful. You can click on 3 dots near my comment and accept it as a solution to help others. This mean a lot to me. Thank you😊
vivek1989
Others
I did many times bro but i think its chipset problem
Exynos 1280 is really an incapable processor at 35k .
Others
Yes definitely brother. It also depends on processors. But still Snapdragon is performing quite good in all factors.
vivek1989
Others
Thats why xiaomi was no.1 in till 2021 when samsung started to give sd chipset in mid range category for the first time
Its cameratoapi is also disabled wow samsung
cs-member11
Others
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Clear the camera lens with a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt, and dust from the camera lens.
* Reset camera settings
Camera > Settings > Reset settings > Reset.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application>Support>Ask a question/Tap an error report>Type your query>Send)
