11-18-2018 01:08 PM in
OthersGreater distances between sender and receiver coils can be achieved when the inductive charging system uses resonant inductive coupling. Recent improvements to this resonant system include using a movable transmission coil and the use of other materials for the receiver coil made of silver plated copper or sometimes aluminium to minimize weight and decrease resistance due to the skin effect.
Source - Wikipedia
11-18-2018 01:32 PM in
OthersSamsung provides two convenient ways to consumers to get involved in Samsung's take back and recycling efforts:-
(i) Fixed drop off locations- includes numerous static locations for consumers to drop off mobile items such as mobiles, camera etc. These locations will be maintained by our authorized partners.
(ii) Collection facility for big consumer electronics products - you can avail pick-up services for television, refrigerators, washing machines etc. by calling Samsung contact center 1800 40 SAMSUNG (1800 40 7267864) or write to us at ewasterecycling@samsung.com.
Regardless of the method, no fee is charged from the consumer for giving the goods for recycling.
Others• During the initial setup after purchase or when restoring data
• When downloading large files
• When using apps that require more power or using apps for extended periods
– When playing high-quality games for extended periods
– When recording videos for extended periods
– When streaming videos while using the maximum brightness setting
– When using the Screen Mirroring feature (When connecting to a TV)
• While multitasking (or, when running many apps in the background)
– When using Multi window
– When updating or installing apps while recording videos
– When downloading large files during a video call
– When recording videos while using a navigation app
• When using large amount of data for syncing with the cloud, email, or other accounts
• When using a navigation app in a car while the device is placed in direct sunlight
• When using the mobile hotspot and tethering feature
• When using the device in areas with weak signals or no reception
• When charging the battery with a damaged USB cable
• When the device’s multipurpose jack is damaged or exposed to foreign materials, such as liquid, dust, metal powder, and pencil lead
• When you are roaming
Others• Keep the device updated with the latest software.
• Conflicts between running apps may cause the device to heat up. Restart the device.
• Deactivate the Wi-Fi, GPS, and Bluetooth features when not using them.
• Close apps that increase battery consumption or that run in the background when not in use.
• Delete unnecessary files or unused apps.
• Decrease the screen brightness.
• If the device overheats or feels hot for a prolonged period, do not use it for a while. If the device continues to overheat, contact a Samsung Service Centr
Others● If you have configured Samsung account in your device and activated Find My Mobile, Remote Control and Google Location Service, then you can track your lost device.
1Logon to https://findmymobile.samsung.com
2Login with your Samsung id and password. Or if you have configured Google account in your device, then you can login with Google id and password on https://www.google.co.in/android/devicemanager .
● You can ring, lock or wipe the data from your mobile. Note- Internet must be activated in the device to use the above features.
● Also if you have activated SIM Change Alert feature in your device , then you will receive a message on the numbers which you have saved in the feature if a new SIM is inserted in your device.
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=126571
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=386417
OthersIf my post help you please ❤ like my past and follow me 😊😊😊
https://community.samsungmembers.com/en_IN/post?postId=401718&categoryId=10011&page=1
Others- Mark as New
11-18-2018 02:45 PM in
Others- Mark as New
Others
