Fonts problems.
(Topic created on: 12-05-2017 09:13 PM)
Doyelchanda
Others
Why Samsung galaxy j7 prime (7.0.1) can't apply downloaded fonts from other sites or app ?? (ex- play store,black mart etc.)
5 Comments
Others
One things I tell you that you can update your phone, but things can't happen again if update your phone . Then you must download from the play store .
Doyelchanda
Others
Download what form play store ??
Others
Would like to tell you kindly follow the steps below to resolve your concern:-
1) Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
2) Please run your device in safe mode.
3) Please do reset your device on factory mode after taking the data backup Via Smart switch. Be sure to hit ♡ when you find an answer that works for you.
Not applicable
Others
just becoz samsung has restricted font usage to monotype imagong inc fonts.....paid font they are. no other fonts will work. unless u download any monotype imaging font from any other source
admin_
Others
Thanks for being with Samsung and sharing your concern. We would like to inform you that the downloaded themes or app should be in supported format so please check and then use the same. Be sure to hit ♡ when you find an answer that works for you.
