Resolved! Solved
Battery issue detected
(Topic created on: 03-05-2021 11:24 AM)
Strangeneria
Others
My setting showing this error message for battery
But when I click it, nothing appears!!
Nothing happens when tapped😑
Samsung_Support1
Others
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
8 Comments
Others
Go to device care and check if there is any issue detected
Others
open Device care , then battery then check your battery history
bhola69
Others
just ignore it
Ehsank
Others
some apps are running on background continuously that's why i guess, open device care, but don't worry ita not a big concern
Samsung_Support1
Others
Others
How to solve battery detected
ha34
Others
Battery issue detected samsung galaxy s9 plus battery lava Las
viru2003
Others
Battery issue found error occurs when the battery is changed.Screenshot_20240824-214258_Samsung Members_128468_1724515979.png
