A71 edge Lighting issue
(Topic created on: 05-30-2022 11:51 AM)
shashankshines
Others
Edge lighting is not activating after turning on from settings. Happening after recent UI update.
Needs this fix asap plz.
15 Comments
Others
Already shared the logs...still no one from Samsung called me for this yet...
Others
No one will call you, will you get a notification, sometime it takes time
TheMystic
Others
Edge lighting only works when you enable 'Show as Pop-up' under notification settings.
If there are multiple notification categories, you'll have to enable 'Show as Pop-up' for each of the ones you want individually.
Others
Cool..Lemme try this..will get back
Others
Not working for me
kroy1234
Others
I don't understand if any users phone have any problem, then he/she says it's issue, kindly note that any issues mean lot of phones have face it , otherwise it's not issue. It's a problem. And in a71 oneui 4.1 update is very clear and non issue. So many users hype them all , I don't mean to u. But it's happening.
