Battery issue PLS Help
(Topic created on: 05-01-2020 04:31 PM)
UchihaR
Mumbai
can any one help me about Battery Draining issue on note 10+, and do anyone know if Samsung has any Plan about improvung Note 10+ Battery stabilization software as well as about the camera, low Light piCS are not that much good. How can I fix this by myseIF?
2 Comments
cs_member9
Mumbai
Dear Samsung Member,
Kindly follow the below mentioned step to improve the performance of the device
  1. Perform Battery Optimization: Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
  2. Adjust screen timeout settings: Settings> Display> Screen timeout> Select minimum screen timeout.
Battery related Concern: For more information, you can also follow given link:
https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
UchihaR
Mumbai
does Your Problem Solved?
