network problem ( too slow) while using on s9 plus.
(Topic created on: 01-27-2019 10:10 AM)
IDCRISIS
Jaipur
I am using s9 plus with Jio.when Jio sim is used with s9 plus..network seems to be inconsistent...frequently dropping internet.....when I use same sim in JIOFI hotspot network is pretty good....Samsung to look into this.Exynos is taking toll on network....Kindly update it......plz share other users their views on this if they are facing same problem.
7 Comments
Jaipur
Same issue face my samsung galaxy s9
admin_
Jaipur
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
AnilBharambe
Jaipur
Good post
Bhaskar8753
Jaipur
Same issue in my galaxy j7 2016.
Jagratidas
Jaipur
wow
himardiburman
Jaipur
nice info
shivamishra
Jaipur
good one
