11-07-2020 10:14 AM in
Jaipur- Mark as New
11-07-2020 11:21 AM in
Jaipur- Mark as New
11-07-2020 11:25 AM in
Jaipur- Mark as New
11-07-2020 02:31 PM in
JaipurA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
11-07-2020 02:32 PM in
Jaipur1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-07-2020 06:27 PM in
Jaipur- Mark as New
11-07-2020 06:51 PM in
Jaipur- Mark as New
11-19-2020 07:37 PM in
JaipurDear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
