Resolved! Solved
wifi data cycle settings problem
(Topic created on: 04-21-2020 12:32 AM)
Not applicable
Hello members...I am using galaxy s9 on android 10 ...here inside connection settings, I can't change data cycle month for wifi...it's fixed..can you tell me is it possible in android 10?if yes then please provide settings here...I am attaching screenshot of that particular 👇
Resolved!
11 Comments
rodentia
i know i'm late to the game, but if you're still looking for a solution... i actually use a third-party app (download in google play) called "Data Counter Widget." you can configure both mobile data and WiFi usage w/ different dates which is great b/c my internet cycle isn't the same as my cell.  you can go into the app which breaks it down by app and filter just mobile or just WiFi if you want.  plus the widget shows a running balance on your phone screen (wherever you put it) for quick numbers.
don't know if this comment will go thru since i'm suggesting an app, but if it does and you see it, i've found it to be very handy! :)
rivvvu
My wifi usage limit is full wat to do know
