what is emergency recovery code in smart switch
(Topic created on: 03-12-2021 11:07 PM)
vishal261214
What is emergency recovery code in smart switch for note 8 please  help for reinstall  note 8 software...
4 Comments
When using SmartSwitch the emergency Recovery code is generated if the installation fails.
To reinstall Note 8 software you have to use Odin method. That's a tricky procedure and can permanently brick your phone. And as far as your issue is concerned I am pretty sure this is not software issue, your display is faulty so better get thay replaced rather than try to reinstall software. 😁
ahme700
ahme700
hay i love your hscks
ahme700
hay i love your hacks
