water resistant
(Topic created on: 11-11-2017 04:33 PM)
Stircrazyleopard2001
I wanted to ask from samsung members that is it still possible to take ur galaxy s8 underwater if there is a minor crack on then edge of the screen???
5 Comments
matrix
yes its possible
but dont expect the device to survive
and if water enters the device say bye bye to your warranty too
yeah was thinking about that too
matrix
its better not to take any chances but without the damages you can
just dont submerge it for too long and dont dive too deep
i spend 20 mins with mine in the water and it still worked flawlessly
granted i had to dry it a hell lot before it charged through the port again but i had a wireless charger so it ddnt drive me completely insane
yeah even I just wanted to know wheather i it can survive in water if by mistake it gets drop in water
admin_
We apologize for the inconvenience caused. We would suggest you to visit nearby Samsung Service Centre so service engineer will examine your device physically.and they will let you know whether it is still compatible with water resistance. Please find service centre details in the link provided http://www.samsung.com/in/support/servicelocation/ Be sure to hit ♡ when you find an answer that works for you.
