switch SIMs for calls and data?
(Topic created on: 03-30-2025 11:41 AM)
SN24U
How to fix the frequently need to switch SIM for calls
2 Comments
ajuneeisnig
If your Samsung phone frequently asks you to switch SIMs for calls, here are some fixes based on your situation:
1. Enable "Ask Before Calling" (If You Want Control)
If you want to choose a SIM before every call:
Go to: Settings > Connections > SIM Manager
Enable "Ask always" under Preferred SIM for Calls
2. Set a Default SIM for Calls (If You Want It to Stick to One SIM)
If your phone keeps asking even when you want to use a specific SIM:
Under Preferred SIM for Calls, choose SIM 1 or SIM 2 instead of "Ask always"
3. Disable "Auto Data Switching" (If Network Switching Triggers It)
Samsung's auto-data switch can sometimes cause issues:
Turn off "Auto Data Switching"
4. Turn Off VoLTE (If One SIM is for Calls and the Other for Data)
Some networks force a switch when VoLTE is enabled on both SIMs:
Go to: Settings > Connections > Mobile Networks
Toggle off VoLTE calls for one SIM
5. Reset SIM Preferences
Toggle both SIMs off and back on
Restart your phone
6. Check Your SIM Card Placement
If the issue persists, swap the SIM card slots or reinsert the SIMs properly. If you use a physical + eSIM, try reactivating the eSIM.
If none of these work, let me know your Samsung model and One UI version, and I’ll suggest more specific fixes!
Samsung_specialist
Kindly note that you have two options to choose from. You can either enable "Ask Before Calling" (if you prefer to have control over the calls), or you can set one card as the default. Could you please confirm which option you would like to proceed with, so we can address this accordingly?
