screen lock pin not working
(Topic created on: 10-29-2019 08:43 PM)
vips1990
I had update my s10 plus before 3 days but after that i am not be able to enter pin as try again popup.
After hard reset 2 times now screen lock not be able to set
Please help
11 Comments
deepak001
It can be because of the beta version so don't worry report it to Samsung. they can fix this issue with a update
Not applicable
only 2 solution is there....1st..wait for stable official update and 2nd downgrade to pie version from service center
Ravi0883
today an update is pushed by Samsung fixing this issue go and update manually
Mita2
my phone also locked... how can i update without unlocking it
Ravi0883
try to hard reset
Mita2
is there anyway to save data
Ravi0883
If you backed up your data it may be recovered otherwise you might loose
it is due to the beta android 10, wait for the stable update or downgrade to pie.
downgrade to pie also still didn't get any solution and now i m unable to enrol also in beta
stuck with no lock option in my phone
