s9+ charging port issue
(Topic created on: 08-05-2020 08:55 AM)
guurikkll
My s9+ has got few issues
1) its now only showing cable charging even original fast charger is connected nad fast charging options in battery settings are also toggled on .
2) its not connecting to pc . I connect it to pc and it started get cable charging . Neither pc shows a connected device , nor phone shows
3) when ever i put only cable into charging port without even connection the wall adapter to the electricity plug , lone cable is also been detected as a usb Device . And it keeps showing that the usb device is connected and disconnected again n again .
           Even while charging if electricity goes off , phone treats connected cable as usb drive .
Please help
cs-member13
Expert Level 4
Dear Samsung Member,
We request you kindly visit the service center as your device needs physical inspection. To check for the nearest Samsung service center kindly click on the link: https://www.samsung.com/in/support/service-center/
