s8plus front glass replacement
(Topic created on: 12-02-2019 02:23 PM)
Ganeshsha
My touch is working fine..Can I replace s8plus front glass alone in local shop??
Is it advisable??
4 Comments
they don't just replace the front glass, instead they replace the whole display.
Suvamdas21
No..
Ganeshsha
one local shop says that front glass replacement cost is Rs.3500.. can I go for it??
lalittt123
he will take your original display and fit duplicate
