s8 power saving mode bug figured out or spotted cozing battery drain
(Topic created on: 03-11-2018 01:12 AM)
mechanicdingo
guys ive noticed that earlier phone used to give good battery durimg power saving mode . top notification used to show two battery recycling icons
now it only shows one battery recycling icon as u can spot the diffrnce between the 2 screenshots and the power saving mode is now ineffective.
i had even reset mah phone . for first few days it gave gr8 battery . but soon the old power saving mode appeared amd battery now is the same 💩 as it was before5ebfe7d3-b981-4ed6-a11d-36a25c9f56b9.jpg
3 Comments
Not applicable
bhai mah nhi my hta h
mechanicdingo
if u dnt understand slang then i feel sorry for u
admin_
Thank you for sharing your concern. The relevant department will serve you better/speedily, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
