s8 battery replacement
(Topic created on: 05-31-2019 11:07 AM)
himanshumhatre
Will my battery backup improve,If I replace my battery on my s8??
8 Comments
Goldychahal
how old is your device?
almost 2years
Fazel
yes it will improve... go to Samsung service centre for the replacement.
HarshalNaik
The battery backup depends upon many things like the device usage.If unnecessary things like auto-sync and bluetooth are kept off it may increase your battery backup..But if the battery itself on your device is defective,then replacing it may solve your problem.
Goldychahal
Samsung said s8 battery will remain at 95% after 2 years...
but atleast it should last for a typical working day on mobile data.I also own an iphone se as a secondary driver it gives me amazing battery stats at the end of the day it shows 30% of battery life with heavy usage
Maverickk
well replacing the old battery with the new one will definitely help in improving the battery backup!
great info
