Chinmay
05-15-2017 05:15 PM in
The Always on diaplay has an adaptive brightness,it changes its brightness level automatically according to the light around the device.
In my device it doesn't work properly it keeps getting too low and too high itself even if the light around the device is stable.
anyone else facing the same problem??
15 Comments
- « Previous
- 1
- 2
- Next »
admin_
05-16-2017 10:28 AM in
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
AdaptiviHomeScr een
09-27-2017 11:23 PM in
Adaptive Display
AdaptiviHomeScr een
09-27-2017 11:24 PM in
Adaptive Display
AdaptiviHomeScr een
09-27-2017 11:27 PM in
Adaptive Display screen mode
AdaptiviHomeScr een
10-20-2017 07:25 PM in
diaplay
kalaiorton
Beginner Level 3
07-17-2018 06:46 PM in
k
- « Previous
- 1
- 2
- Next »
