s25 ultra charging notification while charging
(Topic created on: 03-15-2025 03:22 PM)
raviks55
since, I bought s25 ultra, I am getting irregular charging notifications even when the phone is connected to a charger.
note that I am using the samsung original 45 W charger and the cable which came in the box.
Can someone help!
8 Comments
sherryf
Visit service center simple as **bleep**
Kaustav_Ray
I understand you're experiencing irregular charging notifications on your Galaxy S25 Ultra, even when using the original Samsung 45W charger and cable. That's definitely not expected behavior, and it's important to address it to ensure proper charging and battery health.
Here are some troubleshooting steps to try:
Check the Connection:
Make sure the charger is fully plugged into the wall outlet and the phone's charging port.
Try a different wall outlet to rule out a faulty outlet.
Inspect the charging cable and port for any signs of damage or debris.
Clean the Charging Port:
Use a small, soft brush or a can of compressed air to gently clean the charging port on your phone. Dust, lint, or other debris can sometimes interfere with the charging connection.
Restart Your Phone: A simple restart can often resolve software glitches that may be causing the irregular notifications.
Test with a Different Charger and Cable: If possible, try charging your phone with a different Samsung 45W charger and cable (or another known-good USB-C charger and cable). This will help determine if the problem is with the charger, cable, or phone.
Check for App Conflicts: Some apps can interfere with the charging process. Try booting your phone into Safe Mode to see if the issue persists. If the notifications stop in Safe Mode, a third-party app is likely the culprit.
Software Updates: Check for software updates.
Battery Optimization:
Check battery optimization for device care.
Factory Reset (Use as a last resort): If none of the above steps work, you may need to perform a factory reset. Important: This will erase all data on your phone, so be sure to back up your important files first.
If none of these steps resolve the issue, it's possible there may be a hardware problem with your phone's charging port or internal charging circuitry. In this case, I recommend contacting Samsung Support directly for further assistance. They may be able to diagnose the problem remotely or recommend that you bring your phone in for repair.
Kaustav_Ray
If this helps, please accept it as a solution. Click the three dots on my reply and select 'Accept Solution.' Thanks!
raviks55
it occurs when the fast charging is on, if I close it and use the charger, there is no issue
cs_member8
Dear Samsung Member,
As per your query, we want to inform you that it is not an issue or bug, this is the concept of the devices. However, If you still facing the same issue in further kindly feel free to get in touch with us.
raviks55
what is this concept of the phone which I dont understand, can you me understand with an example. I am constantly getting notification of charging while it is getting charged and it is all random. seems like it happens only when fast charging is on. can someone who know about it help!!
raviks55
this is how it irritates with constant notifications - how to stop it1742393246859.jpg
raviks55
can someone help, my phone keeps on waking up while fast charging!
