s24u battery problem
(Topic created on: yesterday)
shashikanth1
idk why but from 2 weeks my phones battery is dying very fast . S24 ultra
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
We regret to hear about your experience with our product.
● Please perform the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Open the Samsung Members app (Battery Status (Battery life + Battery Capacity))
● Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
● Please always use a standard charging procedure. Always charge in one go instead of charging many times as it affects the life span of the battery and battery performance.
● Perform Battery Optimization: Battery optimization helps you boost the battery performance of your device. To check battery optimization:
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage, and Memory
● Turn off Bluetooth, Wi-Fi, mobile hotspot, NFC, etc . when not in use.
● We recommend you avoid using in areas with low network/fluctuation because these cause the battery to drain very fast.
● Reduce the display brightness level or set the device to auto-brightness mode.
Swipe down on the home screen to open the notification panel
Turn on the Auto-brightness option if available.
It will automatically adjust the display brightness of your device according to ambient light & will reduce battery drainage.
● Adjust screen timeout settings: Settings >> Display >> Screen timeout >> Select the minimum screen timeout.
● Kindly check which application or interface is using more battery from device care and try to update the app or avoid using that app.
● Close background running apps.
● We request you to turn off the auto-sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
Swipe down on the home screen to open the notification panel.
Turn off the auto-sync option.
You can reset your device by following the steps:
● Kindly create a data backup of your device via the SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
● Remember the Google password before resetting the device because it is required during initial setup.
● If you do not remember then reset (Forgot password) your Google account.
If the issue still occurs, please visit the service Centre for a physical inspection of your device. You can locate your nearest service Centre with this given link: https://www.samsung.com/in/support/service-center/
