recording problem on vowifi
(Topic created on: 01-14-2020 10:58 AM)
Chitwan
After using vowifi on s10+ ..my call recording has stopped...any solution?
9 Comments
krishnakhumar
may be upcoming update they will surely fix it bro don't worry
SliceSupport
There is no technology developed to get call recording while you are making WIFI CALLING
so update can not do that for you
only option you have USE THIRD PARTY CALL RECORDING APP ( truecallers etc )
truecaller call recording works fine for wifi calling record
Not applicable
the technology is avaialable, for reference see this video
https://youtu.be/ao9R49W2x24
Chitwan
i cant find call recording feautre in true caller app..can u plz tell me..where is it?
Wasifrahman
No app supports recording on wifi calls
Samsung_Support4
Hi there,
We would like to inform you that the call recording feature is not supported in the wi-fi calling.
Regards,
Team Samsung Members
uvmaniacs
samsung, thats not true. xiomi has this feature. fix this asap
Arunmc
Yes, same here 😒. coming from an OnePlus user, the only reason I bought S20 ultra is because, only samsung has LTE varient watch. After pre-booking and got the phone found all the issues..
1)No guesture navigation which they implemented after 7 months in UI-2.5.
2) Cant record calls in VoWiFi.
3) No SPay in watch. That too only in India where other countrys has.
4)No proper support from Samsung and parts are very expensive when compared to OnePlus.
5) Great fan base who always point to either Google or Carrier or any other third party possible. If nothing, they point to Government regulations which no where any one can find.
Will never recommend Samsung to any one
PranilKaldeep
when will get security update for M51..last update was on 1st August..
