pubg lag s7 edge on every settings
(Topic created on: 10-22-2018 07:09 PM)
Wabii
Hi
I need suggestion help.
Pubg is not supporting more then hd settings and even on hd or low setting giving me lag.
After oreo update lag was disappeared but now started again.
I haven't installed the latest update.
But have installed 2 updates after oreo or 1 .
I use greenify and clear recent apps. Tried gfx tool. Before version 7 of pubg its works well but jow it doesn't work. Tried samsung game enhancer it show fps before oreo update but now doesnt.
Have degraded screen resolution to fhd from game launcher but nothing much.
4 Comments
DrZiaDawarMusaki
Beginner Level 3
lag is from pubg server.. maybe the next update of the game will fix it
Push2000
i use s7 edge too but i have not experienced any lag. It might be from the pubg server.
Wabii
how can it be from the server.
but it do sometimes occur less
testkenend
suushdhttps://community.samsungmembers.com/en_AE?projectId=0&meta=#/post?postId=387291
