problem with wifi
(Topic created on: 11-05-2019 01:02 PM)
chaitanyaG
When Ever ON wifi on my S10 Automatically mobile are getting off
12 Comments
kabirraihan
Reset your phone
chaitanyaG
doing the same every time but it is not the solution Right?
Bro..perform..reset network settings once
settings>general management>select reset>click on reset network settings
or
perform normal phone reset settings
or
perform reset apps prefrences
settings>applications>click at 3 dots>select reset apps prefrences
or
check if its happening after installing any recent apps
or
forget all previously connected wifi networks on your device and restart it
just give a try
chaitanyaG
thanks Bro
chaitanyaG
thanks bro
chaitanyaG
not done yet evng i will do
KP01
s10 have lot of problems bro
chaitanyaG
🤦‍♂️🤦‍♂️I don't know bro i had seen some reviews and bought s10 now iam locked
KP01
i understand.. one of the main issue i have seen that for playing pubg and lots of high graphics games in display a yellow spot is coming.. shocked after seeing that.. asked Samsung about this but no satisfactory answer we get from them..
