GinnuS10
04-10-2020 03:51 PM in
When i am using conference call option then i am unable to listen any audio from another side of call and they can't listen my audio as well. Pls help
4 Comments
hedgehog
04-10-2020 04:04 PM in
reset call app
hedgehog
04-10-2020 04:05 PM in
probably the service provider has weak signal
hedgehog
04-10-2020 04:13 PM (Last edited 04-10-2020 04:13 PM ) in
do 2 things meanwhile use a good pair of headphones because call transmission is priority over audio signal so for clarity u need quiet environment use headphones with good mic and second instead of samsung phone app for conference use zoom from Android Store it's cheap and uses VoIP it's fast and has more clarity and can connect upto 5 callers and yes read this article it'll answer your queries 👍👍👍👍👍👍👍👍👍
which phone u have s10????
https://www.androidauthority.com/why-conference-calls-sound-bad-and-what-you-can-do-about-it-1010669...
hedgehog
04-10-2020 04:13 PM in
