panorama editing resolution problem
(Topic created on: 11-14-2018 10:24 PM)
sachinT
While editing the panorama images and finally when I save the that picture
 The resolution of that panorama get reduced and the quality also reduced
So want suggest Pleasee fix this as soon as possible
 In normal images editing the the resolution does not reduce & quality remains superb
 but only problem occurs in panorama editing images resolution
 Thank you
3 Comments
Sushantnayak
You have raised a very nice query @sachinT. Send a feedback with images you have edited & send it to Samsung team through member's app , you will surely find a solution. a25dbe07-437c-47cd-97fe-350c076aa8a0.jpg
pankajur
https://youtu.be/C_Z_CwriIuc
admin_
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
